| | | Forums66 Topics128,141 Posts1,056,488 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2011 Posts: 21 'Bolter | | 'Bolter Joined: Jul 2011 Posts: 21 | I have a '59 235 and it does not have a "road draft tube" but does have a vented oil fill cap on top. The block has a freeze plug where the tube would go. Do I need to have a vent for the lower crank case or will the top oil cap vent suffice for the engine? The engine is a complete rebuild. Photo attached. 235 engine Any help is appreciated. thanks
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy coralhead, your 235 does not "need" a road draft tube, the road draft tube was designed to draw fumes from the crankcase of the engine while the vehicle was moving down the road. Without the road draft, all the air movement in and out of the engine must take place at whatever vents remain, your vented filler cap may be sufficient, hope that helps. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | If you do not have the tube you are likely to smell blow-by fumes in the cab. Most of the time when the tube is removed and the engine is plugged it is because a PCV system is installed to re-burn the blow-by.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Sep 2011 Posts: 1,456 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,456 | Any crankcase vent system needs to draw fresh air in an expell blow - by gasses, a single vent cap won't do very good job. Get a road draft tube at least. Modify to PCV, not that hard and helps keep crankcase dilution way down. Factory PCV was useed on many 261 truck engines as wall as 235s in forward control bodys and optional on others. I cut the downpipe off an old road draft tube & welded a washer to accept a grommet and PCV valve. BC Good looking rig you got going!
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | |
