| | | Forums66 Topics128,088 Posts1,055,998 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2011 Posts: 814 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 814 | I just got some new dash knobs from Classic Parts and was wondering how they attach to the cable (one is choke and the other is throttle). I can't see how the originals were attached, really. It almost looks like a tight press fit. There is no set screw on either the originals or the new knobs. I was going to use the new knobs with some cable I already had around. Just need to figure out how the knobs attach.
Thanks.
1956 Chevy 3200
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | they're molded on, a VERY tight press fit - you'll need to break off the old ones and figure a way to melt or glue the new ones on so they can work without being pulled off  Bill | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Sep 2011 Posts: 814 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 814 | Tim, did you use JB Weld? Sounds like the only way to go.
1956 Chevy 3200
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I use JB Weld to hold a knob on the Ranco heater-valve control-rod used with a deluxe heater. Nothing else worked - the JB Weld is holding up fine. JB Weld has almost never failed me in many odd applications.
| | | | | Joined: Jan 2012 Posts: 10 New Guy | | New Guy Joined: Jan 2012 Posts: 10 | They sell them with cables, thats what im getting for my 58. If u already have the knobs only do tbe jb thing | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | I removed mine from the cable by heating them up with a heat gun a little but you can over do it real easy and they loose their shape. I haven't tried to put them back on yet but a little heat will be involved I'm sure. 3M 8101 like I used on the steering wheel repair will be my first choice for glue as it's less permanent than JB weld (though not as cheap).
