6 members (Opelika Tom, 46 Texaco, ndkid275, Stan 58, RoadsScholar, Otto Skorzeny), 115 guests, and 1 robot.
Topics128,083
Posts1,055,967
Members48,430
#819427 01/25/2012 12:37 AM
I just got some new dash knobs from Classic Parts and was wondering how they attach to the cable (one is choke and the other is throttle). I can't see how the originals were attached, really. It almost looks like a tight press fit. There is no set screw on either the originals or the new knobs. I was going to use the new knobs with some cable I already had around. Just need to figure out how the knobs attach.
Thanks.
1956 Chevy 3200
they're molded on, a VERY tight press fit - you'll need to break off the old ones and figure a way to melt or glue the new ones on so they can work without being pulled off ohwell
J-B WELD
Tim, did you use JB Weld? Sounds like the only way to go.
1956 Chevy 3200
I use JB Weld to hold a knob on the Ranco heater-valve control-rod used with a deluxe heater. Nothing else worked - the JB Weld is holding up fine. JB Weld has almost never failed me in many odd applications.
They sell them with cables, thats what im getting for my 58. If u already have the knobs only do tbe jb thing
I removed mine from the cable by heating them up with a heat gun a little but you can over do it real easy and they loose their shape. I haven't tried to put them back on yet but a little heat will be involved I'm sure. 3M 8101 like I used on the steering wheel repair will be my first choice for glue as it's less permanent than JB weld (though not as cheap).
Give me ambiguity
or give me something else
Moderated by  ndkid275, Phak1
