6 members (TexasA&M48Truck, Charles in CA, MickeyP, Nick in Manitou, Ponchogl, 55shaker), 125 guests, and 3 robots.
Topics128,026
Posts1,055,406
Members48,422
#818199 01/21/2012 1:42 AM
I have a SM420 transmission coupled to a 3.90 differential (open driveline). The truck is a 49 1/2 ton GMC. Story is to long, and actually might not have all facts as how does this combination got made. Anyway, the transmission has the driven gear in it (perfect condition) with 12 teeth. The drive gear is missing. According to parts book it should have 4 teeth. Looked everywhere and haven't fount this gear, it has to be metal not plastic. Haven't made my mind yet over tire size, but might install 15". In Oldcarmanualproject.com states that only '54 Chevys had 3.9 gear ratio and gives the combination of driven/drive 19/6 teeth. On the GMC parts manual for a 3 speed transmission and a 6 teeth drive gear it asks for a 18 teeth driven. The ratio matches for 3/4 ton pickup prior to 1948. In summary, I don't know what the heck I'm talking about. The actual problem is I don't find metal drive gear. Also, will it affect having a a 4 speed instead of a 3 speed gearbox in the speedo reading, even more, since I have the 3.90 differential. Shall I use whatever I found and put an adapter that corrects the problem? I'm really puzzled. Thanks for any light sheded on the subject.
3B Offline
Hy Chinito Quan, you could put an ad in the parts wanted forum for the gear you're looking for. Even if you can't find all the correct gears there are suppliers of ratio adapters to correct ratio errors. The only time a transmission can adversely effect the speedo is when it's an overdrive, and no provision is made to correct the speedo reading when the transmission is in overdrive, hope that helps.
So it seems useless to try to find the drive gear new? Thanks
Sorry bud, can't help you. I went to Transmissioncenter.com to see what they had. They had everything under the sun, except what you need. Try to find somebody parting out an old SM420 and buy an adapter to get the correct speed, is all I can tell you.
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
I have sent you a PM about this.
My Blog
Dave: PM back. Just a question, is everybody that lucky with their transmissions that came complete, that I saw practically no one asking for this gear. Also, no one offering after market (Jim Carter, American Classic, etc.)?
