3 members (Hambone, Jon G, Rusty Heaps), 295 guests, and 3 robots.
Topics128,151
Posts1,057,009
Members48,460
#819087 01/24/2012 12:42 AM
Hello,
Was wondering what your folks' suggestions would be to remove the valve lifters/tappets out of the engine?
Thanks!
I used a pair of pliers with cardboard taped over the jaws. I only grabbed them at the upper portion so if I did leave a mark it wouldn't matter. (it didn't) Did you ever get it to turn over?
Nope!Not turning. Taking it apart....
Thanks for your suggesttions!!
If you haven't done it already, you might want to put some type of chemical to loosen them up in the bores. I personally like Fluid Film for this type of situation.
1951 1 Ton Completed
Fluid Film. I always call it sheep-spray. I've always pictured a Loney-Tunes type factory, where sheep go in one side, and chops and fluid film comes out the other side.
If you've never seen Fluid Film, or used it, its got lanolin in it. I use it to coat my steel clamps when exposed to salt water. In fact, I've had clamps in the ocean for a month at a time, with no corrosion. It does smell funny though! Good stuff.
To keep this vaguely stovebolt related.... Outside behind my garage, languishing under a tarp, is my spare 216 motor. I know its' preserved, as I coated it with fluid film three years ago!
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1949 GMC Panel Truck
1926 Model TT Truck
