3 members (j05h79, Phak1, Jay R),
73
Mod | | | Forums66 Topics128,154 Posts1,056,837 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2005 Posts: 481 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 481 | Looking for suggestions on the best type of tool for use in cutting body panels, (i.e., back rear lower cab corner panels, floor boards, etc.) | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | I find it depends on access to the cut, if there is a second layer to worry about and the material thickness. So far I've used my sawsall with metal blades, my angle grinder with various cutoff blades and I recently started using die grinder cutoffs for tighter confines. I don't have a torch. For the things you listed I'd go with angle grinder and a box of cutoffs I think.
| | | | | Joined: Jun 2005 Posts: 481 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 481 | Thanks Caso. I was leaning toward the angle grinder with a guard (trying to be all about the safety aspect). I have 4 1/1" end grinder. Also do not have a torch, but don't believe that would be my tool of choice anyway.
Raleigh 58 | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | The best all purpose cutting tool I've used is a Dotco angle die grinder. Two downsides are the cost of the Dotco and the compressor since it requires a fairly capable compressor. There are cutting jobs a Dotco can't do but for a good all around, easy to use, multi-purpose cutter it's a good one.
| | | | | Joined: Jun 2005 Posts: 481 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 481 | Tiny,
Thanks. I just looked up this tool using google as i wasn't familiar with it. WOW! you were right about the cost. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | an angle die grinder doesn't have to be expensive, and even the less expensive ones are exceptionally useful if you have a compressor Bill | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | Wow is right... for that kind of money you could buy a compressor for $400 and five HF die grinders for $20 ea. and not worry about switching attachments, just swap tools. Of course the HF will not run all day like the Dotco but if my compressor ran all day my neighbors would drop a load sideways.... besides what little work I do with a DG doesn't justify something high end, just something that does the job.
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I bought an HF angle die grinder and it ran for a total of 10 seconds before the gears in the angle head stripped. I bought it on an unrelated trip to Wichita and it sat in my tool box unused for a year before I decided to use it. I have other quality die grinders that I normally use. Of course it was out of warranty when that happened. One one of the myriad examples I have of HF tools being junk. If you're only going to use it sparingly buy a Craftsman or other mid quality tool before you waste your money on HF. The $75 Taylor in Bill's link would probably be light years ahead of HF. My experience with Dotco is through my 30 years of using them in aircraft manufacturing.
| | | | | Joined: Jun 2005 Posts: 481 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 481 | To all my supportive Stovebolt friends out there;
Thank you for your usual exceptional input. I like to ask around for others' experiences before making a purchase of a new tool and especially for something I have never attempted.
Looks as if it depends on how much a tool gets used as to the quality one should look for when making that purchae,
I also enjoy seeing the photos some of you haveposted. They give me a lot of inspiration. One day my son and i will be there, too.
Raleigh (NC) '58 | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | Don't forget Dremel. Mine did all sorts of duty from cutting steel frame sections, rivets, sheet-metal, rubber and plastic, etc. With the right blade you will be amazed | | | | | Joined: Dec 2011 Posts: 110 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2011 Posts: 110 | Best and the cheapest I've found is a Craftsman 4 1/2" electric hand grinder with 4 1/2 cutting blade installed (I get mine at Home Depot, $1.98ea). More power and cutting adlity than an air tool and less punishing than a sawsall.
1959 Shortbed stepside 1/2 ton project ![[Linked Image from i236.photobucket.com]](http://i236.photobucket.com/albums/ff117/olddaze/Chevy%20truck%20project/photobucket-4342-1325944221019.jpg) | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | I have been waiting for many years for my HF tools to break so I can complain. Still waiting...........
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Mar 2011 Posts: 229 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 229 | i bought a HF angle die grinder works fine for me. but i really like chicago pneamatic tools seam to work well and last a long time. have many of their air tools and will buy many more. check with your local parts store i think their pricing is pretty good when on sale.
MO's 1951 chevy 3100 resto mod project
| | | | | Joined: Oct 2010 Posts: 171 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 171 | Air poweres or electric a grinder/die grinder will be the best tool for cutting out rotten metal. Once you have used it for a while you may find that the guard will be in the way, just make sure you have your safety glasses and leather gloves on. The elctric grinders woork great and you don't have to buy a huge compressor to run it. On another note the tool is only as good as the cut-off wheel, the wider/thicker the wheel the more material you'll be cutting and the slower the cut time. Wholesale Tool sells some great wheels - we us a 6"x.040" and a 4.5"x.035"( http://www.wholesaletoolcompany.com/?gclid=COORuKaT260CFYvRKgodkC3xmA ) on a 4.5" grinder and it works perfect. And this one in a die grinder http://www.wholesaletoolcompany.com/?gclid=COORuKaT260CFYvRKgodkC3xmA
....David
| | | | | Joined: Mar 2011 Posts: 229 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 229 | just bought lots of ten and twenty cutoff and grinding disc on ebay cheap. their cheap enough i can go through two or three and still be cheaper than the local guys. check it out
| | | | | Joined: Dec 2006 Posts: 97 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 97 | One best keep a very good grip on a angleguard grinder in use with no guard my cousen got his cut bad when one kicked back on him he had the thing up near his head ... | | | | | Joined: Dec 2006 Posts: 97 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 97 | useing a angle grinder one should have good grip on it with no guard on ,my got cut real bad with on guard on one ..had it up near his hard and it kicked back on him . | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 |
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 |
