4 members (2-Ton, 78buckshot, TUTS 59, Wally / Montana), 80 guests, and 2 robots.
Topics128,060
Posts1,055,835
#817897 01/19/2012 11:36 PM
Just curious.
Did they follow the 235" all the way thru 1962?
3B Offline
Hy 68ironhead, I think 59 but I'm not 100% sure.
Riding in the Passing Lane
I would say 59 also.
1972 Chevy c10 Cheyenne Super
1959 with a 6 cyl.
My Blog
1948 for passenger cars, 1959 for 6-cyl trucks.
Harvester
Will a 58' starter solenoid switch fit on a 52' starter? Only difference I can tell is that the 58' has a side terminal where as the 52' only has the top positive terminal.
It is not really a solenoid but the switch interchanges.
My Blog
The term "solenoid" has been used. So, just to complicate this discussion, it should be noted that a starter solenoid (an electric solenoid) was used on a few truck engines from 1948-1959. Forward Control ("step van") trucks had an electric solenoid on their starters, as did automatic-transmission trucks from 1954 through 1959. However, the vast majority of trucks used a foot-pedal (foot-actuated) starters through 1959.
Thank you gentlemen....looks like 1959 is the consensus.
