0 members (), 128 guests, and 2 robots.
Topics128,167
Posts1,057,021
Members48,458
Ha guy's I am looking once again for a wiring diagram for an 8 wire Dominion turn signal switch. The part no is 70-8033.Seven wire is the common one so maybe a diagram of that would do.
Len
layback
Have you tried the tech tip
http://www.stovebolt.com/techtips/turn_signal.htm
there is a section called
"WHAT IF I CAN'T FIND A WIRING DIAGRAM?"
You make a chart and use a meter.
thats what I had to do for a switch I had with no diagram
https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=711927
Good Luck
Ha DADS50.
Still wishing for an original diagram.If not.
Len
layback
