7 members (eclector, 32Fordpuchoptop, Hotrod Lincoln, dt235sd, MickeyP, 2 invisible), 154 guests, and 1 robot.
Topics128,033
Posts1,055,531
Members48,425
#817372 01/18/2012 8:18 AM
Hi have a 37 with the crank out window everyone i have talked to says no matter how well installed they eventually leak, i was considering a modern glue in type window but two things missing i need a template for the larger glass and i need to know if the cab flex will crack it once its intalled anyone done one like this? love to see the build pics of it
1937 1/2 ton
Daniel,do you have any pics of the windshield aperature?
I shouldn't worry about cab flex,the urethane bond will form a flexible mount to some degree.
If the cab flexed enough to crack the glass,you would have bigger problems to worry about!
I imagine it's do-able but would like to see a pic or two before I commit myself........
More pix on Flickr.
I've seen that done on hot rods, so maybe searching the hot rod parts guys may be helpful. Just a thought.
Drew
