3 members (66flea, 1955 1 Series, UtahYork), 321 guests, and 5 robots.
Topics128,156
Posts1,057,017
Members48,460
I'd appreciate someone refreshing my memory. On a say '50 Chevy 1/2 ton, there is a metal arm type arrangement that supports the forward end of the emergency brake cable coming from the rear wheel. I would like a description of it or a photo would be better. I assume this part is bolted to the frame. Thanks
Last edited by Woogeroo; 01/19/2012 10:35 AM. Reason: added year/make/ton to topic
Thanks so much for sending the photo. It was a big help.
I have a 52 3100 and it is slightly different. It has a round shape on the end of that bracket that the cable goes through. Then a pinch bolt to lock it in place. So I guess there are different types out there. Probably changed with the year model. I actually need the other end that is bolted to the backing plate. It also has that round shape for the cable to go through. Yours may be different since the other end is different.
'52 3100 "once a Marine, always a Marine!!
I think these are the same views as Gus posted. You may not be seeing the bracket in the
right light because of the nice clean black undercarriage of Gus’s truck:
http://www.pbase.com/dennygraham/image/141004100/large
http://www.pbase.com/dennygraham/image/141004101/large
http://www.pbase.com/dennygraham/image/141004102/large
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
