11 members (FAST55, panel fan, Wayne67vert, Gdads51, Lightholder's Dad, gswbbc, 48jim1ton, frogfarmer, tclederman, Ponchogl, 1 invisible), 106 guests, and 0 robots.
Topics128,049
Posts1,055,553
Members48,425
Apprentice
Apprentice
I'm looking at a Carter YF that has a Delco sticker stating "Rebuilt for General Motors Corporation by an Independent Rebuilder". There is no 3 or 4 digit number ending in "s" anywhere on the body. The air horn has the number "6-1658" cast in it. The body has "Carter YF", "Made in USA" and "2207" cast in it. The cast iron throttle body has the number "1-630" cast in it. I don't have the bolt spacing dimension. I searched the Forums for "1-630" and found one that also had "938s" on the body but this one doesn't have that. Could the "1-630" throttle body have been used on several different models? I'm looking for a Carter carb to put on my 1950 216. Any help ID'ing this thing would sure be appreciated. Thanks!
Carburetion specialist
Some of the early AFTERMARKET only YF's were identified by tag only.
Jon.
The Carburetor Shop
Apprentice
Apprentice
So, if the tag is missing is there any other way to tell what this is? By part numbers or combination of part numbers? Thanks for your help.
Not easily.
Jon.
The Carburetor Shop
