10 members (Gdads51, panel fan, Lightholder's Dad, gswbbc, FAST55, 48jim1ton, frogfarmer, tclederman, Ponchogl, 1 invisible),
121
0
Mod | | | Forums66 Topics128,049 Posts1,055,553 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#81721 08/20/2007 6:07 PM | Joined: Apr 2007 Posts: 30 Apprentice | | Apprentice Joined: Apr 2007 Posts: 30 | I'm looking at a Carter YF that has a Delco sticker stating "Rebuilt for General Motors Corporation by an Independent Rebuilder". There is no 3 or 4 digit number ending in "s" anywhere on the body. The air horn has the number "6-1658" cast in it. The body has "Carter YF", "Made in USA" and "2207" cast in it. The cast iron throttle body has the number "1-630" cast in it. I don't have the bolt spacing dimension. I searched the Forums for "1-630" and found one that also had "938s" on the body but this one doesn't have that. Could the "1-630" throttle body have been used on several different models? I'm looking for a Carter carb to put on my 1950 216. Any help ID'ing this thing would sure be appreciated. Thanks! | | |
#81722 08/20/2007 6:12 PM | Joined: Nov 2002 Posts: 2,763 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,763 | Some of the early AFTERMARKET only YF's were identified by tag only.
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | |
#81723 08/20/2007 9:22 PM | Joined: Apr 2007 Posts: 30 Apprentice | | Apprentice Joined: Apr 2007 Posts: 30 | So, if the tag is missing is there any other way to tell what this is? By part numbers or combination of part numbers? Thanks for your help. | | |
#81724 08/21/2007 2:22 AM | Joined: Nov 2002 Posts: 2,763 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,763 | Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | |
