| | | Forums66 Topics128,078 Posts1,056,021 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2011 Posts: 103 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2011 Posts: 103 | My '48 came with a 12 volt voltage regulator and a starter with s solenoid. I now have a salvaged stomp starter that came to me with a battery cable and a cut off piece of 10 ga. wire. Where does the 10 ga. wire go? To the ignition switch? | | | | | Joined: Feb 2004 Posts: 29,792 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,792 | It goes to one side of the ammeter. The other ammeter connection is the junction point for wiring to the voltage regulator "Bat." terminal, the ignition switch, and possibly the headlight switch. When it's wired that way, the ammeter will accurately indicate current flow in and out of the battery. During normal running, the charging system provides current to operate all the electrical demand, and the leftover current goes through the ammeter to recharge the battery. Jerry
| | | | | Joined: Nov 2011 Posts: 103 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2011 Posts: 103 | Thanks Hotrod. My next step then is to get a generator. My gen. is shot and its a 6 volt. I got my '48 chev in the middle of a restore and upgrade to 12 volt so I don't know what has been changed if anything. There is a 12 volt regulator and maybe a 12 volt starter. Just trying to figure out the rest of the wiring. Thanks again. Ben | | |
