5 members (Phak1, Gray_Ghost, NJC, Otto Skorzeny, UtahYork), 102 guests, and 1 robot.
Topics128,057
Posts1,055,810
#800630 11/24/2011 6:29 PM
My '46 GMC had 7.50 x 16's on the front and 9.00 x 16's on the rear. Probably used as a farm truck. I want to go to a radial. Any idea what current size I should be looking at.
46andonehalf #800699 11/25/2011 1:13 AM
Try going with a LT235-85r16. It is about the narrowest yet tallest tire you can get that looks original.
1941 G506
More
1946 3800
Pic
More
1946 3600
Pic
More
1924 Ford Model T Fordor
641Workmaster #800806 11/25/2011 5:21 PM
I have 225/75/16's on my truck. They are only slightly shorter(maybe 1/2 an inch) than the 7.50/15's I took off. They look good and don't seem out of place on the old ride.
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
Whitedog #801008 11/26/2011 2:56 PM
Anyone know a website that shows dimentions of bias ply tires and radial tires? Could help make tire choice easier.
I run LT 215/85 R16 on my '54 3100. Tallest/narrowest radials that I could find locally. They stand 29-1/2" tall. I keep them pumped up pretty full to give a tall/narrow look. My truck was built at the factory with 6.50/16 (RPO 282M "6.50x16 – 6 ply tires + Hvy Rear Spring"). Standard size was 6.00-16
- Lonnie
My '54 3104
LonnieC #801027 11/26/2011 4:11 PM
I assume you are going to replace the rims also? I have the same dilemma as sooner or later I will need to upgrade to radials. Probably go with steel one piece wheels and some sort of tubeless radial. Because I have such a high gear ratio, I would like to go with a larger diameter tire as I can to give me a bit more road speed.
Keep us posted and through in some pics...
my 3600
David Gilmore
Stovebolt Pictures
Paint progress
____________________________
1950 Chevy 3600
DMGfifty #815682 01/12/2012 6:26 AM
LT 235 85r 16 will be 32 inchs high and will bring your rpm down to 3000 at 60 the tire the truck came with new is onely 30.5 and left you at 3200 at 60
sundown #815689 01/12/2012 8:01 AM
Talk to Coker tires, they could steer you into in the right direction.
46andonehalf #815979 01/13/2012 9:00 AM
I've seen lots of guys go for 215/85R16. Nice and tall.
Moderated by  Dusty53
