5 members (Gdads51, TUTS 59, MickeyP, tclederman, 1 invisible), 75 guests, and 1 robot.
Topics128,049
Posts1,055,695
#815839 01/12/2012 11:17 PM
Is there a way to bench test a gas gauge to see if it is still working. I have it out of the truck and the truck has no gas tank at the moment so I can't just ground the sending unit lead to check it. It's a six volt gauge from a 56 gmc. Years ago (back when I would have bet lots of $ that I would not own the truck this long) the gauge did work after I changed to a 12v system. I had a voltage reducer on it and when it did quit working I just cut wires off the gauge and forgot about it, not knowing if the gauge or reducer went bad. Now that the truck is getting fixed up a working gas gauge would be nice. I would like to test it before I lay out more $ for a "new" gauge, Thanks
1955 Second Series GMC
"Done - A 50 Year Journey"
Follow in the DITY
-- No one said it was going to be easy
rbs56 #815868 01/13/2012 1:14 AM
Check this discussion out.
When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car.
-Unknown-
