0 members (), 347 guests, and 1 robot.
Topics128,101
Posts1,056,180
Members48,436
#814598 01/08/2012 11:30 PM
im starting to fix my 63 c60. replace the floor pans and rockers but what do i start with first the floor pan or the rockers or cab mounts brakets
1963 Chevy C60 Apache Dump Truck
Stovebolt Gallery Page
Photobucket pictures
3B Offline
Hy Perry Dean, welcome back, you know I'm no bodyman, but I would do the rockers first, then the cab mount brackets, and finally the floor pans. My theory is, doing it that way should help to keep everything in place.
I just rebuilt the A pillar on my '47. Inner panel, intermediate and outer panel. Painful lesson.
Photograph everything from every angle.
Then establish known points on parts that will not move- draw a line between two known holes, for example, and photograph that too.
Then make many measurements to parts that will move, ie parts you will bend or remove and replace.
if you can, make opposite measurements on the other side of the cab to establish how symmetrical your cab is. If the cab is symmetrical, you can use the opposite side as a model.
Make lots of diagrams of the measurements.
it will allow you to replace and position panels with some degree of conviction that they are in the right place.
I thought I had made enough measurements but I had not. I relied on the photos and the other side of the cab and I am sure it is all within .5mm (20 thou) and thats probably as good as it ever got. It looks fine on reassembly.
Any work around the doors- fit the door , hang it right, and align the parts to that- that way, your door gaps will be correct when you are done.
you need to remove panel parts, and support the cab, in such a way that it will change shape as little as possible during the operation. So mounting the cab on an accurate dolly is a good idea.Use solid wheels on the dolly, and have the wheels have marked positions on a garage floor for fitting parts. Garage floors may vary in level a lot, even if they look flat.
Good luck! It was difficult finicky work but apart from massive care, I think anyone can do it.
'47 Canadian RHD 1.5 ton truck
thanks 3B and anyoldiron as allways this site is the place to be. i will put as many pics as i can so others can learn from my mistakes ooohhh and theres gona be mistakes im sure but thats just part of it for me live and learn
i will start with the rockers and take many measurements as possible
thanks so very much
got my parts in today so i will have to start with rockers first anyway got all but the passenger floor pan (back order)
be fore you start weld in cross brases in the doors to keep the cab from shifting when cut out parts it helps a lot
