| | | Forums66 Topics128,078 Posts1,056,035 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Are there any six volt strip lights that can be used for a safety stop light in the back window of an AD Truck cab?
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I wasn't able to find any doing a search but you can mount a standard third light that uses a bulb and put a 6v bulb in it. You can get 21cp out of an 1129 6v bulb. The 1129 uses the BA15S socket.
| | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | When I was a kid, I thought these little traffic signals in the rear window were the cat's meow. Pic 1 mountedPic 2 NOS Ebay $249 (ouch!) Ebay #130565745406 shipped from ezpeleta, buenos aires, Argentina.
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Aug 2005 Posts: 341 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 341 | Take a look at this site... Brakelighter
Allan ----- 1951 GMC 1/2-ton Two 1953 Chevy 3100 5-window | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Great link! Looks just like what he's looking for.
| | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Yup. That looks nice. I am afraid of the dim 6 volt tail lights.
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | With some creative application of bulbs you can make your tail/brake light a lot brighter. The tail light on my '38 coupe is brighter than an 1157 and the brake is about the same as the 1157. I'm still at 6v.
| | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | I have those little funky tail lights. I have noticed that there are two socket holders for the inside. One is straight and used the small bulbs. The other is zig zagged so the stop light bulb can be larger. This may fit the bill. I just have not figured out how to put the sockets in the zig zag holder since they are sold separate and without the bulb socket. The zig zag holder is sold through Chevy Parts of America. Maybe just a simple phone call?
TIA
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Is this your tail light? If so it's the same basic as my '38 coupe and the fix for you should be the same as mine was. No new parts required except for bulbs, just a bit of tweaking of the bracket. If the above is your tail light put a slight bend in the bracket that holds your sockets. Make the bend half way between the sockets and angle it toward the back of the housing. Bend a little at a time until you have room for a #81 bulb in the top socket (6cp) and a #1129 in the bottom socket (21cp). This will give you a 6cp tail light as opposed to the 3cp of a 12v 1157 and either a 21cp stop light (same as the 1157) or a 27cp stop light depending on whether your tail light stays on when the brakes are applied like my '38 does or if the tail light goes out. One caveat is there IS a difference in how the housings mount so the shape at the back (mounting side) is a bit different. The car housing that I have provides enough room to make that bend. I've not adapted a truck housing bracket so while it SHOULD work there is the possibility it may not. Don't be real aggressive on your bend so that you can "un" bend it if necessary. If you decide to try that on your housing post here if it works for you and I'll write up a tech tip to submit to John and Peggy so everyone can benefit.
| | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | You da man, Tiny.
That is the funky little tail lights. I will work on bending the bracket and finding the 'more candle light bulbs' in 6 volt.
Thank you very much
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Keep in mind that you don't have to get the complete bulb fully inside the housing, just enough to clear the lens. The bulb closest to the lens will be the 1129 which is only on with the brakes so even a plastic lens should be OK. Just make sure it isn't actually touching the lens if it's plastic.
| | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Jan 2001 Posts: 1,424 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,424 | I got in trouble with a FARM USE plate, I don't live on a farm so I have a different plate on there now in the same location with a light on each side of the plate, can take a picture tomorrow if anyone's interested. Cosmo
~ Cosmo 1949 Chevy Half Ton Rocinante, like Don Quixote, he is awkward, past his prime, and engaged in a task beyond his capacities. "...my good horse Rocinante, mine eternal and inseparable companion in all my journeys and courses." ...Don Quixote, Cervantes "If you come to a fork in the road, take it."...Yogi Berra "Rudeness is the weak man's imitation of strength." ...Eric Hoffer
| | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Cosmo. I like the idea. That is a license plate holder and tail light from some vehicle?
Joker - you got the right idea. Think it would work in Dallas?
| | | | | Joined: Jan 2001 Posts: 1,424 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,424 | Here's the new version... Another view. The pictures don't show it but at night my home-job 3rd brake light(s) are really bright and they are at eye level so they are really visible. The three pieces are mounted directly to the board, all wiring runs underneath and behind the box. They are Guide brand license plate lights eliptical in shape with the insides painted bright white for greater reflectivity.
| | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | sure it would work.........I use to drive my old binder with farm plates in the city all the time.. we have good cops here, wont bother an old man... right Dennis Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 |
