Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (Svcattle, baldeagle), 145 guests, and 1 robot.
Topics128,274
Posts1,058,432
Members48,489
#814549 01/08/2012 8:02 PM
I have been looking for a 261 for my 58 Apache for a while now. A friend told me he had a Chevy inline 6 in a chassis sitting behind his shop so I gave it a look. The engine is sitting in what appears to be a 1 ton chassis. (no body) It is definately a 216/235/261 engine and is mated to a hydramatic transmission. There is a tag on the transmission bellhousing that says "Engine serial number" and is stamped: 0146629 F54L. The area behind the distributor is hard to read, but I think it is stamped ?1901?872. The engine has an updraft intake manifold with a Zenith carb and a rear dump exhaust manifold. Everything appears to be original. Does anyone have any ideas about this engine?
Ron
Diceman #814577 01/08/2012 9:54 PM
Black plate or orange plate on the transmission?
F54L is a 235 mated with a Hydra-Matic transmission on a 3700 truck.
http://chevy.oldcarmanualproject.com/chevyresto/54057.htm
A 3700 was a Forward Control Chassis - a step van - it would have had a Carter updraft carburetor as you describe, I think.
http://chevy.oldcarmanualproject.com/chevyresto/54151.htm
