8 members (Jethro in Va, 3B, Wingnut68, moparguy, Peggy M, Possum, 1955 1 Series, dt235sd), 65 guests, and 1 robot.
Topics128,197
Posts1,057,400
Members48,471
Pictures
Any questions?
Who owns this car with the peace sign, mag wheels, and 4 on the floor?
Dude- 1948 Chevrolet Thriftmaser 3600
https://i.imgur.com/NN2ehrsl.jpg
A couple of tips.
2 quarts of POR15 was about $100 from my local auto paint store. It gave me two coats. I could have gotten a gallon for about $30 more. I would be careful with coating too much. I used the existing angle strips and the fit was very tight.
A creeper would be very useful! I didn't have one, and wished I did.
I did not remove the bed. It would have been easier, but it was not terrible leaving it on.
I notice you sanding what grit(s) did you use. Can I assume lightly between every coat. Did you sand the raw wood prior and once after last coat?
Cavebull
cavebull
Stovebolts - so easy even a Cavebull can do it.
https://www.flickr.com/photos/dodsonbrett/collections
behr AND por15? which was for what?
Cavebull
Some 150 on the bare wood. Smoothed it out some and knocked the edges down. Splinters and what not.
Some 180 between coats. Very lightly, just to smooth things up a bit.
Some 220 on the last coat.
See Mar-k's website. http://www.mar-k.com/wood_finish_testing_ii.html
There is also another thread, not too far back, that addresses this.
POR15 is a tough chassis paint. The Behr was an exterior paint for UV protection.
Nice job on your AD. Did you follow the Mar-K recommendation for allowing no longer than 3 hours of drying time between coats(specifically for the POR-15.....or just you just allow the to dry fully and scuff sand the first coat as to give the second coat something to bite into?
Chuck
Nice. I like that you kept the wood stock looking rather han show.
Drew
Looks like your truck is ready to haul something in that bed now.
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
What kind of wood did you start with? I used white oak, and had a terrible time with the little pores in the wood. I would apply the POR15 and in about 10 minutes, little bubbles would appear. I basically kept sanding and painting until all the pores were filled before topping with POR Blackcoat.
Just wanted to point this out to anyone attempting to paint white oak.
