3 members (MickeyP, papas52, Otto Skorzeny), 116 guests, and 1 robot.
Topics128,157
Posts1,056,885
Members48,458
can you use a wire wheel on a drill to clean the rust off of axle spindles?
#813889 01/06/2012 4:24 PM
Can I use a wire wheel to clean up axle spindles? I am hoping it won't damage where the bearings sit.
I would not do it, use a degreaser and a green scotch pad. If the spindles are pitted badly I would replace them.
evac34 #813915 01/06/2012 5:28 PM
What is it you are trying to clean up?
If it is dirt or grease I would use soap/surfactant or solvent. If the spindle surface itself is damaged somehow, I would use a very fine emory cloth like you would use for a crankshaft journal.
If it is rusty and corroded, you may be looking at a new one.
Kurt
I found an axle someone already used the wire wheel on. Should I pass on it?
someone was selling it. The first picture he sent lit looked a little pitted or discolored. He said they were not and when he resent the pictures the spindles were beautiful but I noticed the wire wheel still on the floor next to the axle. Could he have damaged it?
evac34 #813934 01/06/2012 5:51 PM
He could have damaged it. Hard to tell unless you can look at it yourself. Sounds sketchy, doesn't it?
Kurt
Are you talking about spindles, or axles? Spindles just have a smooth mounting point for ball or roller bearings, no problem with rust removal with a wire wheel. The bearing race does not turn on the spindle. Rear axles have a roller bearing surface ground onto the axle, and rust pits or deep grooves caused by an aggressive wire wheel will cause bearing roller wear. Please clarify your question.
I had a '75 Dodge 3/4T and a front bearing went out. The race welded itself to the spindle. A friend cut the race off with a torch. I used a file to clean up the spindle as best I could.
Even though the new race had a bit of wobble in it, it worked just fine including long trips. On those trips, though, I would stop and feel for excessive heat. It was fine.
So pitting in the spindle might not be a problem, especially if the original high points can hold the race properly. I'd keep an eye, ear and hand on it, though.
