| | | Forums66 Topics128,163 Posts1,056,962 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2011 Posts: 71 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2011 Posts: 71 | Hello, I've recently finished re-wiring my 59 Chevy with a reproduction harness from Classic Parts. I have run into three hiccups:
1) With a fully charged battery, the ammeter always reads halfway between D and the middle. Immediately after start, and after a 15 mile drive. I have a 235 with a rebuilt internally regulated alternator. The battery is a couple months old, and even with running it for 25 minutes it still has the juice to turn the truck over. Any ideas?
2) The right tail light is pretty dim, and doesn't shine as brightly as the driver's taillight when the brake is applied. The light has two wires, black and white. I'm thinking maybe a bad ground? Do I need to sand off the paint where the light bolts to the truck?
3) I can't get the gas gauge to work. Can anyone tell me how many wires should be hooked up to the sending unit? There were two, but the kit only came with one. It connects to the Full side of the gauge.
Thanks for the help,
Vince
| | | | | Joined: Sep 2010 Posts: 166 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 166 | Coachie, just did my '59 with same harness... 1)Mine has generator, I had no problems with that so can't help you there. 2)Yep, sounds like you need a better ground, scratch paint under bolt or use ext tooth lock washer. 3)2nd wire on sending unit goes to ground. I just made up my own wire to ground it. Darren. | | | | | Joined: Nov 2009 Posts: 239 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 239 |
1. Switch the wires on the ammeter. 2. Try switching the wires. If that does not work then your though about the ground is probably correct. 3. The sending unit needs to be grounded to work (the second wire).
When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car. -Unknown-
