| | | Forums66 Topics128,181 Posts1,057,189 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2011 Posts: 57 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 57 | I haven't had a chance to try finding original paint on the pieces yet but does anyone know what color the bellhousing and 3 speed transmission should be on a '50 pickup? I'm thinking the bellhousing should be the same gray as the 216 engine but I'm not so sure about the transmission.
I'm restoring the pickup to as close to original as possible so I'd really like to know how they did it from the factory.
Thanks, Shawn
Shawn
1950 3600 Pickup, 1958 Plymouth Belvedere
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | The clutch, flywheel, Bellhousing and inspection pans were on the engines when they were painted so they were painted the same engine gray. The transmissions and rear axles were shipped as bare metal. Not absolutely original, but if you don't like the look of rust most of the vendors and many FLAPS carry Dupli-Color DE1651 Cast Coat Iron paint that looks pretty natural on the running gear. There are a few pictures at the top of this page of an SM420 ready to install that was painted with the DE1651: http://www.pbase.com/dennygraham/sm420_rebuild Also the steering gear box was painted with it: http://www.pbase.com/dennygraham/image/136174246/original Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Sep 2011 Posts: 57 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 57 | Thanks for the info Denny. I would have never guessed they didn't paint the transmissions and, especially, the rear axles. That helps alot.
Shawn
Shawn
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Denny,
Were the enclosed driveshaft rear-ends not painted? I thought I saw a recent post wherein someone said it was painted a semi-gloss black.
I have left the enclosed driveshaft rear-end exterior unpainted on the 1/2 ton 1954 pickup I am restoring; but, I was recently considering painting it semi-gloss black.
If it was unpainted when it left he factory, I can live with that.
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Tim as you know, I'm not an "expert" but I've never seen one with any paint on it. As I said, I'm using the Dupli-Color Cast Coat on anything that was supposed to be bare, I just feel that old gal has seen enough rust in her life time.
Denny G
