| | | Forums66 Topics128,094 Posts1,056,056 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2011 Posts: 110 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2011 Posts: 110 | My `58 1/2 ton has a 3 speed on the column and I'm thinking of putting an OE 4 speed floor shifter in it. Will it change my final drive ratio? Or is high gear in both the same?
1959 Shortbed stepside 1/2 ton project ![[Linked Image from i236.photobucket.com]](http://i236.photobucket.com/albums/ff117/olddaze/Chevy%20truck%20project/photobucket-4342-1325944221019.jpg) | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | High gear is the same, 1:1.
Bill Burmeister | | | | | Joined: Dec 2011 Posts: 110 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2011 Posts: 110 | In that case I'll stick with the 3 on the tree. That way MaMa can sit alittle closer.
1959 Shortbed stepside 1/2 ton project ![[Linked Image from i236.photobucket.com]](http://i236.photobucket.com/albums/ff117/olddaze/Chevy%20truck%20project/photobucket-4342-1325944221019.jpg) | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | If you're wanting to get a bit more speed (or more accuratly, lower rpm at higher speeds), you might look into a 3 speed with the Borg-Warner overdrive. That will keep the column shoft, but get you a .70:1 overdrive ratio. The overdrive unit itself is more of secondary 2 speed transmission, so you would have not only the overdrive gear, but also a split gear between 2nd and 3rd (great hillclimbing gear, BTW). That version of the 3 speed is a direct bolt in, only really needing a lockout cable, a solenoid, a kickdown switch, and the wiring harness to install. The '55-'57 Passenger version is identical to the Truck version '55-'59.
