| | | Forums66 Topics128,126 Posts1,056,353 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2011 Posts: 21 New Guy | | New Guy Joined: Feb 2011 Posts: 21 | Looking for some direction on where to start my troubleshooting on this one. I was driving my ‘51 half ton yesterday and the engine died, tried to restart and the battery was gone. Tried to jump, engine turned over but would not start. Truck was in a high traffic area so I had to get it towed home. Engine is a ’55 second generation 235 and all 12 volt elec items were transferred over with it - coil, distributor, generator, voltage reg. Battery is brand new, gas tank is full. I’m thinking that the voltage reg is the culprit but thought I should be able to jump start even if the voltage reg went bad. Also can I trouble shoot a voltage reg with just a standard voltage/ohm meter? Thanks much. | | | | | Joined: Feb 2011 Posts: 21 New Guy | | New Guy Joined: Feb 2011 Posts: 21 | While searching the forums I found one item that I may have missed when converting from 6 to 12 volts and that is the ballast resistor, this has not been installed. | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | regulator won't keep it from starting, check the ignition circuit, make sure you're getting spark, might have fried the points or damaged the coil
Bill | | | | | Joined: Feb 2011 Posts: 21 New Guy | | New Guy Joined: Feb 2011 Posts: 21 | Thanks Bill, waited for the battery to charge and started checking voltage, no voltage going into coil. Started tracking down that issue and found that the power wire going into the ignition switch came loose. That was an easy fix so we're running again but that does not explain the dead battery. I don't have an ammeter so I can't check the voltage reg but I pulled the cover and the voltage reg looks very new, that does not confirm it is set up properly however. I may have the generator tested first to make sure that is ok. Mark | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | A simple check it to remove the positive terminal to the battery when the truck is at about 1100 rpm. If it continues to run when the engine is revved up, the generator is doing what it is supposed to do. Here's a LINK that I have for understanding the electrical system. | | | | | Joined: Feb 2004 Posts: 29,810 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,810 | Pulling a cable is a very risky way of checking the generator output. It's a lot simpler to ground the Field terminal at the generator and see if the voltage rises when the engine speed is increased slightly (the lights get brighter). Don't overdo it- - - -I've seen a 12 volt system go above 20 volts with the field grounded with only a moderate increase in engine speed. Pulling a battery cable can result in a voltage spike of around 100 volts in some cases. I've seen it on an oscilloscope several times. Jerry
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I wouldn't continue to drive it without an ammeter. You probably would have seen some trouble coming if you had a working one. | | | | | Joined: Feb 2011 Posts: 21 New Guy | | New Guy Joined: Feb 2011 Posts: 21 | Thanks for the info sheet on the charging system, great to have! | | | | | Joined: Feb 2011 Posts: 21 New Guy | | New Guy Joined: Feb 2011 Posts: 21 | To clarify my early post-truck does have an ammeter gauge in the dash, the ammeter I was referring to was the one in the service manual with the four leads, thanks. | | | | | Joined: Feb 2011 Posts: 21 New Guy | | New Guy Joined: Feb 2011 Posts: 21 | Jerry, I'm going to give this a try. If I want to put a meter on this to check out voltage increase, where is the best place to check? Thanks, Mark | | | | | Joined: Aug 2011 Posts: 835 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 835 | You can check it at the battery.
Kurt | | | | | Joined: Mar 2011 Posts: 229 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 229 | all you have to do to see if your charging is put a volt meter across the battery, it should read about 12.6 volts not running and running you should see somewhere around 14 volts or more. if your regulator is bad it will be very high probably above 16 volts.
MO's 1951 chevy 3100 resto mod project
