| | | Forums66 Topics128,113 Posts1,056,279 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2011 Posts: 23 New Guy | | New Guy Joined: Dec 2011 Posts: 23 | I am trying to shore up orig. color combo,I beleive transport blue was body color. I cannot seem to verify trim color it seems to be a light creme color. Any help and reference to paint chip location to view would be great. I have checked out a few sources here but they dont seem right. Thanks | | | | | Joined: Dec 2011 Posts: 23 New Guy | | New Guy Joined: Dec 2011 Posts: 23 | | | | | | Joined: Dec 2011 Posts: 23 New Guy | | New Guy Joined: Dec 2011 Posts: 23 | Paintscratch.com had a great site for early 50's and later color chips. | | | | | Joined: Dec 2011 Posts: 23 New Guy | | New Guy Joined: Dec 2011 Posts: 23 | Found colors, now need to convert codes to present ones. My paint store could not go off these numbers and could not locate any usable chip. Should i go elsewhere? He usually is pretty good. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Near the bottom of the Tech Tip is some information on how to contact PPG. They might be able to give you a modern "offset code". Your paint store might be able to match that code.
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Here's a couple sites that can get you the codes. Auto Color Library, which will have the PPG codes, and Paint Reference which will have the oem code, PPG, and Dupont codes.
Bill Burmeister | | |
