2 members (ronsway, Bill Hanlon), 106 guests, and 4 robots.
Topics128,172
Posts1,057,035
Members48,458
I
I Offline
I didn't really see a sub forum to deal with this but please move if needed.
As far as I know these are the original rams put on when the dump bed was built in 49.
It lifts the bed but the passenger side ram is weak, lower than drivers side with a load in the bed. When I lift it up all the way the passenger side ram squirts oil out the top of the cylinder. I pulled the ram out and took pictures.
ram side
ram top
top
If the pictures don't show up I will try them again.
It is a simple ram with only one hose going in the bottom. The reason I am posting here is I am hoping someone has some experience with these old rams and can give me some info before I head out to the repair shop and pay too much to get it fixed. It looks like the top comes off with just a retainer ring holding it in. I have not tore into it yet.
Anyone have any ideas to fix it??
edit reason: trying to fix pictures
My new 1949 Chevy One Ton Dump Truck. Still have it but parked, needs a new motor.
1953 2 ton parts truck Long Gone
1957 GMC LCF On 75 Cadillac Eldorado Frame
Updated Feb 2021
Sounds to me like the seals inside the cylinder are bad allowing oil to get on the top of the piston. Your pictures are so small it's tough to see what you have.
1941 Chevy
"First rebuild - complete!"
Follow the story in the DITY
1941 GMC resting peacefully
1946/1947 Chevy Street rod on s10 frame complete
1945 GMC panel truck in line for restoration
1941 Plymouth stock complete
1941 GMC COE in restoration process
Read his Project Journal
1941 Chevy Coe uncertain future resting now
Ditto on the tiny pictures. If the top of the cylinder with the ram coming out of it can be unscrewed, or removed by taking a retaining ring out, it can probably be rebuilt. The entire top of the cylinder must be removable, however. Your #2 picture looks like a "welded" cylinder. I think I'd prefer to buy a new cylinder from somewhere like Northern Tool & Supply with the same diameter and stroke, rather than trying to patch on an old one, unless it can be fixed easily. Definitely don't let someone at a rebuilding shop take you to the cleaners just because it's old. Hydraulics are very simple- - - -pressure times piston area equals lift- - - -nothing complicated at all if a new cylinder will bolt in!
You can put the new o rings and packing in your self if you can get it apart, the pictures didn't come up for me you may wnat to try them again.
I
I Offline
I didn't think to put this in big bolts because my truck is only a one ton.
ram
ram top
top of ram
I am trying to make the pictures big enough to see.
Updated Feb 2021
If you can get it apart, the rod is not bent or scratched and the bore is not pitted from rust, you shold just be able to reseal it. A good hyd repair shop should be able to get you the seals or reseal it for you if your not comfortable doing it. I would think a price for them to do it would be $250-$300, but i may be wrong on that.
52' Chevy 6400 2 ton
Having been in this type of business nearly all my adult life I wouldn't even think of attempting a rebuild if it costs over a hundred. A new cylinder can be had for $200-300 and you'd be way ahead of the game.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
Some cylinders come apart easily, and the seals are not terribly expensive, but others are a real nightmare to disassemble, and the rebuild kits can be very expensive. It is hard to tell by your pictures, but the ram does not appear to be in very good shape (free of dents, scratches, debris etc.) If that is the case, it will quickly damage the new seals. Good luck, Scott
1954 Chevrolet 4400 1.5-Ton Dump Truck
1946 Chevy 1.5-Ton Dump Truck
1944 Chevrolet 1.5 Ton Dump Truck
1955 4400 Dump Truck
1951 2 Ton Stake Body
Ram looks Ok to me, it appears to have a snap ring holding the end cap in place, walk the ring out, pull the shaft and packing plug out and see what you have, seals and O rings should be simple enough to get, you might as well get enough for both rams and then your done with it.
I
I Offline
I am working till Thursday and will take them apart then. The top of the ram in the pics looks like crap but it doesn't go all the way in the cylinder. I will take pics when I pull them apart.
Updated Feb 2021
