2 members (Leo, 1 invisible), 90 guests, and 4 robots.
Topics128,192
Posts1,057,234
Members48,465
Ok I am getting ready to reassemble. Looking for advice on drilling and bolting the two L shped rails to the metal sides? How many bolts, where should they be, and any reccomend bolts?
Thanks, Denis
Thanks Denis
Used to drive Subs, prefer old rides
1952 chevy 3100, 5 window
I think originally, they were welded to the sides ? You didn't say if you are going stock or modified look. I used polished stainless strips. On mine, they laid up tight against the side, and only bolted thru the bed. Looks OK
1940 Chevy KC 1/2-Ton
Here is a link to our online 47-53 angle strip installation instructions http://www.mar-k.com/37-53anglestrips.pdf.
This should answer all of your questions. Best of luck with your build.
Thanks, Denis
Thanks Denis
