| | | Forums66 Topics128,188 Posts1,057,216 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2010 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2010 Posts: 47 | Ok I am getting ready to reassemble. Looking for advice on drilling and bolting the two L shped rails to the metal sides? How many bolts, where should they be, and any reccomend bolts?
Thanks, Denis
Thanks Denis Used to drive Subs, prefer old rides
1952 chevy 3100, 5 window
| | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | I think originally, they were welded to the sides ? You didn't say if you are going stock or modified look. I used polished stainless strips. On mine, they laid up tight against the side, and only bolted thru the bed. Looks OK | | | | | Joined: Dec 2005 Posts: 406 Shop Shark | | Shop Shark Joined: Dec 2005 Posts: 406 | Here is a link to our online 47-53 angle strip installation instructions http://www.mar-k.com/37-53anglestrips.pdf.This should answer all of your questions. Best of luck with your build. | | | | | Joined: Dec 2010 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2010 Posts: 47 |
