2 members (GrandpasJimmy, dunfire), 64 guests, and 4 robots.
Topics128,194
Posts1,057,263
Members48,466
Hi,
I got an awesome block heater that is to be installed in place of one of the freeze plugs. How do those guys come out? Without doing any damage, of course. Is there a preferred one to choose to remove for installation of the little heater? thanks, Scot
Take a drift and hammer and hit it near the outside edge, it will turn sideways in the hole and then you can grab it with channel lock pliers and lever it out against the block.
1945 Chevrolet G 506 1.5 Ton Military 4X4
1967 Jeep Cj5 with 283 SBC
thanks, sounds like that will work!
- Lonnie
My '54 3104
I have a couple 261's with genuine GM block heaters in them and they are in the hole closest to the front. The others may not have sufficient room in the jacket for the element.
You Tube
