7 members (SWEET, Donf, rfs56trk, sron48, 78buckshot, Wickedbass, JW51),
60
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,023 Posts1,055,367 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2010 Posts: 91 Shop Shark | | Shop Shark Joined: Oct 2010 Posts: 91 | found a replacement rear axle for my 46 gmc one ton.Its a corperate 14 bolt from either a early 70,s J20 Jeep 4x4 pick-up or 3/4 ton chevy pick-up.Not sure as it came out of a swamp buggy project gone bad. The spring centers are 52.5" the same as the original.WMS-WMS with SRW hubs is 67",If I get DRW hubs which I am looking for the WMS-WMS is 63" the same as the original.Now for the good part,the gear ratio is 373:1 the truck drivability has improved dramaticaly over the 513:1 that the old rear end had.It also makes finding wheels and tires a breeze.Now I just need to figure out the front wheel and tire issue
| | | | | Joined: Sep 2011 Posts: 255 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 255 | Congratulations. Oh, thanks for the compliment, I get that rear-end comment all the time. Careful though this is a family forum.
Whats the front-wheel issue going on? | | | | | Joined: Oct 2010 Posts: 91 Shop Shark | | Shop Shark Joined: Oct 2010 Posts: 91 | I thought that subject title would get some smiles.Stay warm it,s still 80 degrees here. | | |
