| | | Forums66 Topics128,149 Posts1,056,817 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2011 Posts: 257 Shop Shark | | Shop Shark Joined: Jul 2011 Posts: 257 | So I'm getting ready to install the flywheel/clutch assy on my 235. I was reading through the manual and it said something about applying Goodyear PliaBond #3 between Flange and Flywheel surfaces. I have looked through several threads on Stovebolt.com and did not see anything about applying any kind of sealer. Can I use Permatex Gasket Sealer or do I even need to do this? | | | | | Joined: Sep 2010 Posts: 166 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 166 | Never heard of doing such a thing! I didn't use anything on mine, never have. Just loctite on the bolt threads.
| | | | | Joined: Jun 2005 Posts: 388 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 388 | I just looked at the 1954 truck shop manual, and it does say to put the Goodyear Pliabond on the flange and flywheel surfaces. I then looked at the 1949-54 Passenger Car Shop Manual, and it does not say anything about using any sealant. I have not looked at any other manuals yet to what else is said. I've never used any sealant in dozens of 235s and 261s, some of which were used for racing. Has anyone ever used the Pliabond or equivalent? Hoyt | | | | | Joined: Sep 2011 Posts: 1,458 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,458 | You don't want anything between the crank flange & flywheel. However, the bolts holes in the crank are open drilled thru and will wick oil past the bolt threads. I use a SMALL amount of locktite pipe sealant w/ teflon (like teflon tape in a tube). Locktite thread sealant works good most of the time but I trust the pipe sealant more. Don't use any type of RTV on the threads.
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | As BC noted, "you don't want anything between the crank flange & flywhee." The manuals were written by technical writers with a degree in literature not mechanics or engineers. I firmly believe that some procedures are misinterpreted by them and the mistakes are not caught by the time the page went to press. I also believe that they were addressing the sealing of the bolts.
Good old automotive sealer, Permatex #2 or 3H which is brush applied has fit the bill for nearly a century. And it's worked for me for a little more that half that amount of time to seal oil, water and gasoline into or out of where you want it to stay.
Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Jul 2011 Posts: 257 Shop Shark | | Shop Shark Joined: Jul 2011 Posts: 257 | Thanks for everones response. I'm new to stovebolts, it seemed strange to me, that's why I asked. I'll pick up some Permatex #2 and be done with it. Thanks again | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Actually I should have said Permatex 3H for this application, same thing just in a more liquified form. http://www.pbase.com/dennygraham/image/140573646/large Denny G
| | | | | Joined: Jul 2011 Posts: 257 Shop Shark | | Shop Shark Joined: Jul 2011 Posts: 257 | I have something similar. It's a Permatex Gasket Sealer, it comes in the same style bottle, has that redish color and looks to have the same consistency as your photo. Will that be ok to use? | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | What's the number????? Sounds like 98H the high tack sealer. Sure that would work, it's non hardening, goot from -65°to 500° and isn't desolved by anything known to man. Go for it.
DG
| | | | | Joined: Jul 2011 Posts: 257 Shop Shark | | Shop Shark Joined: Jul 2011 Posts: 257 | What's the number????? Sounds like 98H the high tack sealer. Sure that would work, it's non hardening, goot from -65°to 500° and isn't desolved by anything known to man. Go for it.
DG Hi, thanks for the response. Yes, it's 98H, thanks for the advice! | | |
