0 members (),
129
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,115 Posts1,056,292 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2011 Posts: 814 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 814 | The only thing I changed was the solenoid. Everything else is as it was when I got the truck.
1956 Chevy 3200
| | | | | Joined: Sep 2011 Posts: 814 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 814 | The casting numbers on my block show that it is a 1955-57 Chevrolet 235, according to one of the links offered here on the Stovebolt site. The starter is a Delco-Remy with the numbers 1108427 2A17 1. As I said earlier, it is not the original foot-activated starter that came with the truck. It would seem the Bendix drive--if that is what it's called--could be the trouble. Are these available or would it be smarter to just get a whole new unit? It would be a shame, since I just put a new solenoid on this one.
1956 Chevy 3200
| | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | Then see if you can get the starter drive. My bet is the grinding you keep hearing is the drive slipping inside. They make a heck of a noise when they wear.
The drive should turn one way, but not the other if you try to turn it by hand. If it turns both ways by hand then it is toast. From the way you describe the sound, my bet the drive is bad.
But make sure you get the right length. May have to drive to a rebuilders to get the right one. Find a starter and alternator rebuild shop and go see them. They can tell you quick if the drive is bad. | | | | | Joined: Sep 2011 Posts: 814 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 814 | Thanks, Roy. It seems like that is the only possibility at this point. I haven't tried turning the pinion gear both ways yet but will do that tomorrow. There is a shop here that I've used before and will likely take it to them. I plan to eventually re-install a foot-actuated starter, so maybe now is the time to do that. I believe Classic Auto Parts had them listed for $134.
1956 Chevy 3200
| | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | You're rebuilder may have one. may be a lot cheaper too. If you want to go back with the stomp starter, check with them first. | | | | | Joined: Apr 2010 Posts: 160 'Bolter | | 'Bolter Joined: Apr 2010 Posts: 160 | Take your old drive with you and compare them,dont depend on part numbers. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Ebay has the 56 foot stomp ready starter for $150
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | His rebuilder can probably fix him up a stomp starter much cheaper.
| | | | | Joined: Sep 2011 Posts: 814 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 814 | I'll give the place a call tomorrow and see what they can do. In the meantime, I have discovered that most, if not all, of the linkage for the stomp starter is still on the truck. I removed it today and it looks like the only thing I might be missing is the return spring. If my rebuilder can't fix me up, I'm just going to by one from one of the usual vendors. They're going for about 135. There is a $50 core charge, but by the time Ipay the postage to send my old starter to them and pay the postage for the new starter to be sent to me, it might be cheaper to eat the core charge.
1956 Chevy 3200
