1 members (Hotrod Lincoln), 41 guests, and 0 robots.
Topics128,035
Posts1,055,560
Page 2 of 2 1 2
Also before we declare "abnormal vacuum" let us consider altitude at your region or maybe you have a test or testemony from a carbureted engine in your area.
Modern engines at idle might see 21 or 22 inches @ sea level changing to 17 inches @ 5000 ft altitude.
Bob Taylor
So I adjusted my valves and figured out why I was showing 13" of vacuum yesterday when I had been showing 17" just a few days ago. When I reinstalled the carb yesterday after removing the jet I forgot to plug my vacuum advance port on the carb. I plugged it and now am showing 17" I'm at 2k ft so I read you lose about 1" for each 1K ft so that would put me around 19" at sea level.
Took the truck for a ride aorund the block, runs great.
I've closed my book on this problem.
Jason
1946 GMC COE
1967 Pontiac Lemans Convertible
http://s1275.photobucket.com/user/jrpontiac/library/?sort=3&page=1
Jason we're happy for you and I know the rest of your family must be glad the problem is resolved too.
Thanks for the good feedback, and we'll give an A for thoughtful diagnosis and determination.
Bob Taylor
Page 2 of 2 1 2
