8 members (68ironhead, Woodcmiami, cmayna, Bill Hanlon, truckernix, Otto Skorzeny, Gdads51, homer52),
94
Mod | | | Forums66 Topics128,259 Posts1,058,297 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2011 Posts: 74 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2011 Posts: 74 | My 1948 chev panel has a wire sticking out of the hole in the steering column but do not see it at the top where I put the steering wheel on. There is a spring but how do I get to the wire. Do I have to pull the whole column apart. Thanks 1948 panel van
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | at the top the wire connects to the mast bearing, you can't see it - when you press the horn button you're applying a ground to that wire to make the circuit, use an ohmmeter to check if the wire out the hole has good continuity to ground Bill
| | | | | Joined: Mar 2007 Posts: 4,217 Moderator | | Moderator Joined: Mar 2007 Posts: 4,217 | Very simple to solder the wire to the copper collar. You don't need to dis-assemble the column, I used a thin re-bar wire to pull the wire up the column. | | |
