7 members (KEVINSKI, Otto Skorzeny, Tronman, Charles in CA, Goach2, 66flea, 1 invisible),
233
Mod | | | Forums66 Topics128,257 Posts1,058,015 Members48,479 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2011 Posts: 50 | I'm plannin on puttin a th350 in my 52'3100 and was wondering if it will work with my stock speedo correctly.Thanx | | | | | Joined: Feb 2004 Posts: 29,919 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,919 | Probably not, but there are plenty of drive gears available to correct any error it might have. A good speedo shop can also set up a speed-correcting gearbox if necessary. Drive the vehicle over a measured mile at an indicated 60 MPH and time the mile. 60 seconds = 60 MPH. Faster or slower can be converted into a percentage of correction necessary that can be converted into the number of teeth to add or subtract from the drive gear it has now. Jerry
