1 members (delky),
65
Mod | | | Forums66 Topics128,049 Posts1,055,740 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#80798 08/02/2007 1:00 PM | Joined: Jul 2006 Posts: 92 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 92 | what rear end can I use ...50 1/2 with 283 P/G..would like easy bolt in...thanks...Virg | | |
#80799 08/02/2007 2:26 PM | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | what are your reasons for changing rears, what are you looking for, an upgrade???
~Jim
#80800 08/02/2007 9:23 PM | Joined: Jul 2006 Posts: 92 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 92 | Yes some upgrade (more speed top end) and the rearend in now has some slop in it and is not the orig. I don't think. | | |
#80801 08/02/2007 11:49 PM | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | 70s early 80s Camaro/Firebird rear will fit nicely under your frame and are plentiful to find. You can swap the gears to get the ratio you want. I found mine on Ebay. jd
~Jim
#80802 08/02/2007 11:57 PM | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | learn to search there is A LOT of info on this topic on this site
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
