Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (TooMany2count, UnclePaddy, Wayne67vert), 105 guests, and 5 robots.
Topics128,281
Posts1,058,460
Members48,490
#80798 08/02/2007 1:00 PM
V
V Offline
what rear end can I use ...50 1/2 with 283 P/G..would like easy bolt in...thanks...Virg
#80799 08/02/2007 2:26 PM
what are your reasons for changing rears, what are you looking for, an upgrade???
~Jim
#80800 08/02/2007 9:23 PM
V
V Offline
Yes some upgrade (more speed top end) and the rearend in now has some slop in it and is not the orig. I don't think.
#80801 08/02/2007 11:49 PM
70s early 80s Camaro/Firebird rear will fit nicely under your frame and are plentiful to find. You can swap the gears to get the ratio you want. I found mine on Ebay.
jd
~Jim
#80802 08/02/2007 11:57 PM
Quote
learn to search
there is A LOT of info on this topic on this site
wink
Jim & Caroline
