0 members (),
170
Mod | | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 71 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2011 Posts: 71 | Hi all - well I have this little glass problem. I had ordered all the glass for the 53 GMC 3 ton, being under the assumption that the cabs are all the same. The wing and door glass went in fine. Couldn't get the back or windshield to go in. After closer examination original glass was far different than the new stuff. Kind of the right shape but not really and much bigger in some spots. Broke 1 side of the windshield trying to get it in and then decided to call company about it. They asked me to send the pieces back and to make a template of my original glass and send it along with it so they could check it out and send out new pieces. Well I spoke with them yesterday and was told that the pcs. I returned were correct for that year, or at least the template they have for that year, so the problem was on my end. It seems that the templates of the originals were not close to what they have??? Something must have happened to the cab he says. But we took the paint down to metal and there were no visible signs of any kind of damage repair. Ok, he then says that he has seen 1 or 2 instances where it was the manufacturing of the cab to blame??? Bad day at the welder? Lovely. I was hoping that we wouldnt have to go the custom route, but I suppose thats the only option. Found a place here locally that comes out and does glass for tractors and such on the jobsite. Said they will take a look at them and it should be no problem. Keeping my fingers crossed. Anyone else ever had this happen?
1st Gen. Dodge Cummins 4x4 OVRTRQD Buick GNX #276 "If it died... we can fix it" | "If your not outraged, you're not paying attention." | "Do you know a large group of baboons is called a Congress? That explains a lot." ~author unwn
| | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | What series GMC do you have? If it is the "fat cab", about all you can do is get one cut. If if it a regular cab, the glass was probably not cut correctly. I run a fleet of Internationals and from 1972 until mid year 2000 they used the same flat glass. We kept spares in stock. Quite often we had misfits that we had to send back. I would have a hard time believing that something happened to the cab or it was a manufacturing defect. I doubt that GM would have made a custom glass for a misfit cab. | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | I've never ordered any glass. I've always took my old glass to the local glass shops, & had it cut to the spec's of the old glass. You should be fine doing it this way. Just a note, it's not the easiest job getting that glass in. I've installed it several times, on several trucks, & it never was easy. The rubber has to be as close to correct as possible also. I've also noticed the new glass is alittle thicker, than the old glass, in my instances. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy OVRTRQD, according to my Canadian parts book there are eight different part numbers listed for windshield glass from 1947 - 53. They are differentiated by "block sizes" A through F, and "block sizes" DR and ER, they all list the size as being 16" X 28", I hope that explains something of why the glass they sent didn't fit. I'm with "spanky" on this, get your glass cut to fit your templates, good luck! | | | | | Joined: Aug 2011 Posts: 71 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2011 Posts: 71 | It's a 455-30. Fat cab? I didn't know about that one.
| | | | | Joined: Aug 2011 Posts: 71 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2011 Posts: 71 | I too noticed the glass was a little thicker. So am I going to have to worry about the windshield rubber? I already ordered it. Won't it be for the size of the pieces I sent back? I mean, it fits well in the opening but if the original glass is smaller, wont it make a difference?
| | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | I think the fat cab started with the 600 series. A 450 should use the same as a pickup. Having the correct rubber is important. In my opinion, Steele makes the best rubber. And as Spanky says, its not easy. Experienced installers make it look easy. | | | | | Joined: Aug 2011 Posts: 71 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2011 Posts: 71 | I look forward to the challenge. I am still wondering why it could be so much different - not going to think on it too much. Hopefully this glass company can help me out (for a decent price anyway). You all are always the wealth of good, correct information, thanks so much!
| | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | Kenneth, the "Fat Cab" conventionals were the 700, 800, & 900 series. The "Fat Cab" COE's were the 500, 600, 700, 800, & 900 series. | | | | | Joined: Aug 2008 Posts: 290 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 290 | I would say that the glass & the cab are ok. I had the same problem I broke one trying to get them in. I reordered the glass & called a buddy of mine that owns a glass shop in a local town & he came to the house & installed all the glass & made it look easy. What I noticed he did while watching him is he set all the rubber out in the sun to warm it up. Then he made it look so easy with rope. When he got done he smarted off saying to leave the glass to a glass guy..... I had to laugh. But he was right he does it all the time & I don't. So needless to say He will be doing my next truck (1948 GMC) in a few weeks.....Hope this helps
| | | | | Joined: Aug 2008 Posts: 290 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 290 | Oh by the way the $150 he charged me to install all the glass in my 1953 chevy 5 window cab was worth every penny. Should of had him do it in the first place. Later
