1 members (carbking),
103
8
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2011 Posts: 133 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2011 Posts: 133 | I am installing a "55" 235 in my "52" 1/2 ton. The front motor mount that came on the new engine is a one piece rubber mount that bolts to the front plate with one center bolt and has two bolt molded into the rubber to attach to the crossmember. I can not find this mount in any of the manuals or parts catalogs. I have the original mount for the old 216 but this one peice mount would eliminate any clearance issuse with metal touching metal. What vehicle would this one peice mount be designed for? Is there any reason I should not use it over the original for the 216?
If you never tell a lie, you never need to remember what you said.
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Sounds like a 1960-61 truck mount.
See the USA in your vintage Chevrolet! My Blog | | |
