3 members (NAPCOStormTrpr, Lightholder's Dad, Gdads51), 82 guests, and 2 robots.
Topics128,076
Posts1,056,280
Members48,441
I am working long hours to finish my 51 GMC and I am currently adding components to the engine. Here is a shot of my engine:
[img]http://inlinethumb62.webshots.com/3325/2580014910100058208S425x425Q85.jpg[/img]
I was wondering, number one, the best way to tap the harmonic balancer in a little more to make it line up, without damaging the pulley: [img]http://inlinethumb03.webshots.com/4354/2830472700100058208S425x425Q85.jpg[/img]
number two, what could be the problem with my manifold exhaust donut gasket? It fits in the bottom half, but the top half is not beveled like the bottom. I'm thinking that the old one might have hardened in the top???
bottom:
[img]http://inlinethumb62.webshots.com/4093/2836954790100058208S425x425Q85.jpg[/img]
top:
[img]http://inlinethumb62.webshots.com/7165/2132884210100058208S425x425Q85.jpg[/img]
any help on either question would be appreciated. thanks.
A piece of HARD wood, like oak or maple, and a BFH (3 or 4 pounder) will drive that damper back until it contacts the timing gear.
The gasket you need has a bevel on one side, and a steel sleeve on the other. The part that goes up into the manifold has a steel sleeve to center it, and the top of the donut is flat. The FLAPS should have a paper catalog of exhaust system parts with illustrations and size measurements.
That is very good to know that all I have to do is get a different gasket. Thanks alot.
