8 members (klhansen, Shade Baby, Shaffer's1950, JW51, Cosmo, Oswald, 2 invisible),
57
Mod | | | Forums66 Topics128,075 Posts1,055,919 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#80695 08/01/2007 2:05 AM | Joined: Jan 2007 Posts: 8 New Guy | | New Guy Joined: Jan 2007 Posts: 8 | Can someone tell me how to install the emergency brake cables on a 66 fleetside shortbed from the single cable to the split cables to the rear brakes? Thanks :hammering: :hammering: | | |
#80696 08/02/2007 3:56 PM | Joined: Feb 2004 Posts: 336 Shop Shark | | Shop Shark Joined: Feb 2004 Posts: 336 | Do you have the cables? On my 66 longed the single cable comes out and attaches to the double cable by a simple brake clevises. The double cable is all one cable that runs from the left drum to the right drum in a long U shaped pattern running up the frame rails. You will need to have the additional brake clevises that mount under the cab on both sides to help support it. Then you have two hangers that mount inside the frame rails under the bed. | | |
