0 members (),
78
12
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#80667 07/31/2007 2:47 AM | Joined: Dec 2006 Posts: 22 Apprentice | | Apprentice Joined: Dec 2006 Posts: 22 | How can I tell if my 350 CI chev has a long water pump or a short water pump?
Fleetside Bob
#80668 07/31/2007 2:54 AM | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy bobtheinsman, most short Chevy water pumps don't have reinforcing ribs or bosses to mount things from, hope that helps. | | |
#80669 07/31/2007 6:46 PM | Joined: May 2005 Posts: 12 Wrench Fetcher | | Wrench Fetcher Joined: May 2005 Posts: 12 | The short water pump rear plate is almost touching the timing chain cover and the long water pump has 1/2 inch or so clearance between it and the timing chain cover. | | |
#80670 08/01/2007 3:40 AM | Joined: Dec 2006 Posts: 22 Apprentice | | Apprentice Joined: Dec 2006 Posts: 22 | Thank you both for the info.
Fleetside Bob
