6 members (1955 1 Series, 53again, Cosmo, Hotrod Lincoln, mason86, Gray_Ghost), 100 guests, and 1 robot.
Topics128,068
Posts1,055,883
Members48,428
Q
QX
Offline
Q Offline
all is good, did not clean gas tank?? after soaking the cyl & took off value cover & soak with gas attative since may. ran good no smoke! put 5 gal in tank all went good. i am off to get eng.key. next brakes think the plunger is shot. not even a bubble when poured in brake fluid. have to check tran. & rear end.
any thought or help
thanks all so far
r.j.
Congrats! It does feel good to get one running after setting for a long time. You should posts some pictures. We love old truck pictures.
Good luck.
Professional Novice
Q
QX
Offline
Q Offline
this truck of mine has it work clothes on!! i will try to get some pictures for you guys. i was a happy 67 yr old kid when it turn over & ran
