4 members (52Carl, FishinToms53, dinosoar, 1 invisible), 78 guests, and 3 robots.
Topics128,127
Posts1,056,677
Members48,452
i have a 1957 gmc truck with the origional dual range hydromatic. it slips. I also have a good 1960 dual range hydromatic. do they interchange or what.who rebuilds the old dual range hydros?
There are some threads over at www.oldgmctrucks.org about GMC hydramatics. I believe they do interchange, but you should double check.
Paint & Body Shop moderator
I grew up around a shop where we rebuilt untold numbers of Dual Range transmissions. Most of them are pretty interchangeable, with the only major differences being the bellhousing bolt pattern, output housing, etc. If your transmissions are both out of GMC trucks with similar engines, they should swap with no problems. Even the ones used behind the Pontiac V-8's should fit the 6-cylinder engine with just a bellhousing change.
Good luck on finding an experienced rebuilder, as it's been over 40 years since they were in general use. The dual range isn't that hard to build, but it does require a few dedicated disassembly tools. There's a BIG servo return spring in there that must be handled carefully if you don't want it to launch across the shop!
go to www.areds.com snag the 800 phone number and talk to Leon. He should be able to tell you whatever you may want to know about that trans.
