| | | Forums66 Topics128,110 Posts1,056,274 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#80579 07/29/2007 3:29 PM | Joined: Apr 2006 Posts: 506 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 506 | What is the correct position of the rear lower shock mount, for a 1950 1/2 ton with tube shocks?
The shock mount bracket, which holds the leaf spring, can be installed 2 different ways.
With the shock post/nut in the "up" or "down" position. This changes the distance of the shock length.
If I use the "up" position and have the correct shock, does it really matter.
-Tom
1950 Chevy 3100 w/ 1956 235
#80580 07/30/2007 2:48 AM | Joined: Nov 2006 Posts: 125 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 125 | i asked this question on oldgmctrucks.com and i have been told to install it in the "down" position. I checked out my old ones and found the spot where the nut had worn down the metal and determined they were installed in the "down" position. I also looked at my pictures of the truck before i took it all apart and that was the same thing i found out. I think this allows for the full range of motion of the shock absorber, but i'm not completely sure. i am fairly sure that i have them correct in the "down" position. | | |
#80581 07/30/2007 3:20 AM | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | Assembly manual shows it down. | | |
#80582 07/30/2007 7:59 AM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Mine are down. You may run out of travel with them up, which would bust them off.
#80583 07/31/2007 5:09 PM | Joined: Feb 2000 Posts: 90 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 90 | I have a similar dilema. I replaced my worn-out leaf springs including my shock absorbers. I installed them per the Assembly manual. For the rear shock mounts,they are in the down position and found that the new rear tube shocks that chevy duty had sold me were(about 1-2") too short to attach. I am now looking to find some new rear shocks by measureing the fully extended distance. Anybody experience this? | | |
#80584 07/31/2007 6:23 PM | Joined: Feb 2004 Posts: 29,805 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,805 | Terry, do you have the weight of the truck sitting on the wheels while you're trying to install the shocks? In a lot of cases, the shock length limits the suspension travel, so the axle housing must be jacked up to get the shock installed. Just a thought, as it's necessary, sometimes, to have weight on the suspension when removing/installing rear shocks. I run the auto shop at McGavock High School in Donelson. Call me or send an IM if I can help out. Jerry
#80585 08/02/2007 4:55 AM | Joined: Apr 2006 Posts: 506 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 506 | Installed the mounts in the down position. Distance between my shock mounts are 21".
Truck is sitting on wheels, but minus the weight for a wood bed.
The rear shocks are Monroe 33049. They measure about 14" compressed, to 23" extended to the very end, when off the vehicle.
The 23" shock just looked over extended at 21". I guess the weight for the wood bed will bring the distance a little closer.
Thanks for the input.
-Tom
#80586 08/03/2007 4:52 PM | Joined: Feb 2000 Posts: 90 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 90 | Hotrod Lincoln, I have only the cab and inner front fenders on a rolling (and Driving) chassis. The bed (with wood) and four fenders are yet to be installed. I may give you a shout when I hang those. But, I am thinking that those springs may have raised the frame further from the lower shock mount. The extra weight may pull the frame into place, but those new springs are stiff (rides like a truck again). I live in green hills when I am not working in Oak Ridge. Thanks for the suggestion, it just might solve it.
Terry | | |
