0 members (),
170
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#80529 07/27/2007 1:31 PM | Joined: Jul 2007 Posts: 6 Junior Member | | Junior Member Joined: Jul 2007 Posts: 6 | I recently obtained a 235 engine that will replace that 216 in my 41 chevy coupe. the 235 engine is set up with hyd valve lifters, and my question on this is the rocker assy the same on both the hyd and the mechanical lifter engines... | | |
#80530 07/27/2007 2:02 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | dckars,
Welcome to the Stovebolt. The rocker arm assemblies should be identical for both types of lifters.
Stuart | | |
#80531 07/27/2007 4:10 PM | Joined: Jul 2007 Posts: 6 Junior Member | | Junior Member Joined: Jul 2007 Posts: 6 | Stuart Thank you for the welcome and the information. Dave | | |
