3 members (55shaker, greenie-reddy, 3100RustyParts), 134 guests, and 3 robots.
Topics128,260
Posts1,058,319
Members48,485
#804757 12/08/2011 2:24 PM
I just purchased a set of vintage (round) amber fog lights with universal mounts. Just wondering if anyone has mounted fog lights on a 1955-1957 Chevy pickup and how they mounted them. I will be using a switch and relay for the electrical portion of the install.
don
Here's how I had set mine up. Fog lights. They were mounted on a pair of L brakets made from 2"x2" aluminum. There was a slight offset (about 1/8") made in the bottom section just below the bumper to clear the splash apron. The brakets were directly bolted to the apron behind the bumper.
I don't have a good picture of what it has now, but the new mounting is very similar. The new one is a 1 peice design, rather than having separate mounts for each light. It's more stable, the lights do not bounce around as much. I'll see if I can get some pix up of it for you, right now I really can't get to the truck to get a good shot.
Bill Burmeister
Bill:
Thanks, fog lights look good. Your truck looks great too.
don
Mine are similar , if not the same year. I used angle iron, 1/8" thick steel. I'd suggest steel over aluminum as it is 3x stiffer so the lights will not vibrate as mentioned above.
http://i843.photobucket.com/albums/...ogress/Exterior%20Completed/2a66a695.jpg
'69 1/2T stepside, Sea Foam Green, 250 L6 w/ 3 on the tree, not an option on it, in the family since new.
I used aluminum because the price was right, FREE! grin
Bill Burmeister
