| | | Forums66 Topics128,204 Posts1,057,292 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2009 Posts: 220 Shop Shark | | Shop Shark Joined: Nov 2009 Posts: 220 | If I swap in an open rear in a '53 3100, will I also need to replace the leaf springs with wider ones? I ask because I was told that I would have to do so on my '51 Chevy Fleetline when I was contemplating the same type of a swap, but I don't know if it's different for a truck.
If I do, what springs are best, and does anyone make aftermarket front mount and shackles?
Thanks...
Chris
| | | | | Joined: Sep 2008 Posts: 130 'Bolter | | 'Bolter Joined: Sep 2008 Posts: 130 | When I did my rear, I used a 69 1/2T van rear. I cut the pads off my old rear set it up and taked them on. Then took the u bolts off and welded them on. Used the original springs. There are shackle rebuild kits out there, I used them they work. Got mine from Orange County Trucks out in Cali. | | |
