| | | Forums66 Topics128,134 Posts1,056,403 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2007 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 46 | I have the original wheels on my 48 chevy half ton truck and I will be updating the rearend and suspension with modern components (mustaang 2 and camaro rearend) the updates will use a 5 lug on 4 3/4 bolt pattern. Is there anyway possible to use my original 6 lug wheels on this truck maybe through an adapter or spacer and if possible what is the widest 16 inch tire I can use on the original wheel. Also, I would like to use radial tires. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | There are 5 to 6 lug adapters. They will alter the scrub radius, and can potentially cause additional wear to the bearings and balljoints. As far as tires, you're looking at perhaps a6 or 7 inch wide tire at the most that will safely work with the rather narrow stock wheels. In a modern tire size, 215 or 225 on the section width. A better route might be to look for a similar styled aftermarket wheel, perhaps from Wheel Vintiques or Early Wheel Company, that is made to fit you new bolt pattern. You can also get a wider wheel if you're wanting a wider tire. You'll want the wheel width bead to bead to be roughly 2" narrower than the section width of the tire.
Bill Burmeister | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | Many discount the wheel adapters because of the blind bolts that hold the adapter on the axle flange. These bolts can loosen up as you drive and cause some serious problems. The only way to check them for tightness is to of course remove the wheel.
If I'm not mistaken, there is a 6 lug MII rotor available. | | |
