2 members (VicZ, klhansen),
118
Mod | | | Forums66 Topics128,072 Posts1,055,904 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2010 Posts: 11 'Bolter | | 'Bolter Joined: May 2010 Posts: 11 | Can anyone tell me or direct me to where I can find the overall length for a 51 Suburban. I'm considering buying one and want to know if there will be any room in my garage after I put it in there....... | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | Its the perfect size. You should buy it. Seriously, it'll be awesome. Buy it. | | | | | Joined: May 2010 Posts: 11 'Bolter | | 'Bolter Joined: May 2010 Posts: 11 | Thanks!
It's pretty tight, it will fit but not a lot of room for anything in front of it....... | | | | | Joined: Sep 2011 Posts: 15 New Guy | | New Guy Joined: Sep 2011 Posts: 15 | Just add on to the garage. You will not be sorry. You don't need much extra room anyway you can fix most every thing on these critters with just a hand full of tools...You'll love it | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | Thanks!
It's pretty tight, it will fit but not a lot of room for anything in front of it....... Let's see... Cool looking 1951 suburban, not much room left in garage or Generic Prius with lot's of room in front of car.. What to do, What to do  | | | | | Joined: May 2010 Posts: 11 'Bolter | | 'Bolter Joined: May 2010 Posts: 11 | The Prius would get parked outside............actually the other option is a 60 Bel Air. Which after some checking is pretty much the same length. I guess now it comes down to how big a project I want to try and tackle. | | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | Get the suburban. You can haul way more in it, and it has higher ground clearance, all the better to run over bodies after the zombie apocalypse. A 60 Bel air is okay if you like new cars...
Just think, you and seven of your closest friends can all ride to dairy queen to get ice cream at once. | | | | | Joined: Jan 2006 Posts: 13 New Guy | | New Guy Joined: Jan 2006 Posts: 13 | I say get the suburban! I recently got one and couldnt be happier!
1950 chevrolet 3100 1951 chevrolet suburban carryall
